Date/Time: Sat, 18 May 2024 11:37:21 +0000
Filling the Area Between Two Study Subgraphs within Different Studies
View Count: 1021
[2019-11-08 21:08:59] |
User24791 - Posts: 44 |
Hello, I am attempting to fill in an area between 2 moving averages by following instructions under Section Title: Filling the Area Between Two Study Subgraphs within Different Studies The final chart display shows the "Fill Area" BUT it is "Offset" and does not align with the Moving Averages . See attached screenshot What have I missed within the instructions Thank you ...David http://www.sierrachart.com/image.php?Image=1573247252667.png |
[2019-11-08 21:24:36] |
Set the scale of the Study Subgraphs Reference to Automatic. Refer to the following: Chart Scale and Scale Adjusting: Opening the Scale Settings Window For a Study For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2019-11-10 23:13:31] |
Fantastic! Thank you John You Da Man!
