Date/Time: Fri, 26 Apr 2024 08:21:28 +0000
v1063 VbP: Multiple Profiles from Start Time to End Time
View Count: 1506
[2013-12-21 01:44:31] |
ganz - Posts: 1048 |
Hello SC Support These options: - Highlight Value Area - Extend Value Area - Highlight Point of Control - Extend Point Of Control are not working for all VP but for a very latest VP only using Multiple Profiles from Start Time to End Time With best regards. |
[2013-12-24 04:18:13] |
We will check on this.
[2014-01-06 22:31:57] |
Al SC Developer - Posts: 434 |
This will be addressed in ver 1073.
[2014-01-07 19:37:35] |
SC Support v1074 VbP using Multiple Profiles from Start Time to End Time when i've set from 2am to 8am the very latest profile is still reflecting by price/volume changes but it's out of the time range. Date Time Of Last Edit: 2014-01-07 19:40:31
[2014-01-07 23:39:45] |
Is this problem new to version 1074?
[2014-01-08 02:18:42] |
SC Support I don't know and I'm unable to check this anymore using nonCLR version. |
[2014-02-17 16:28:29] |
SC Support v1093 FYI: The issue is still there. |
[2014-02-17 16:46:19] |
SC Support Также для режима Multiple Profiles from Start Time to End Time функция Extend Point Of Control -> Until Future Intersection работает неверно, а именно: POC пересекает любое количество баров не замечая их, если они не принадлежат другому периоду по критерию условия from Start Time to End Time Тоже самое и для Extend Value Area -> Until Future Intersection Date Time Of Last Edit: 2014-02-17 16:51:35
[2014-02-18 03:37:11] |
VbP using Multiple Profiles from Start Time to End Time when i've set from 2am to 8am the very latest profile is still reflecting by price/volume changes but it's out of the time range. Также для режима Multiple Profiles from Start Time to End Time функция Extend Point Of Control -> Until Future Intersection работает неверно, а именно: POC пересекает любое количество баров не замечая их, если они не принадлежат другому периоду по критерию условия from Start Time to End Time Тоже самое и для Extend Value Area -> Until Future Intersection What you are saying is that when extending until future intersection, the bars in the chart that are outside of the times for the volume profile, are being used. This is how it is designed, and there are no plans to change it as it will start getting increasingly complicated to implement this differently. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2014-02-18 08:00:43] |
SC Support there are no plans to change it
Обычно смысл функции Until Future Intersection (POC/VAH/VAL/High/Low/Close) заключается в фиксации этих существенных уровней, дабы в будущем отследить/не забыть оценить/ поведение цены при следующем/ближайшем к ним подходе/проходе.This is how it is designed
ваша реализация подразумевает что-то иное?если нет - то эти линии, прошивающие график цены насквозь при включенной опции Until Future Intersection выглядят необоснованно, имхо as it will start getting increasingly complicated to implement this differently
с учетом наличия данной функции в прочих реализациях/платформах: именно в виде визуального контроля касания бара при первом пересечении, то ссылки на сложность реализации выглядят не слишком здорово. но вам виднее, конечно. удачи в делах. |
[2014-02-18 08:42:44] |
SC Support as it will start getting increasingly complicated to implement this differently
на взгляд дилетанта: - закрепить за POC/VAH/VAL для VbP:IDn глобальные переменные - сравнивать начиная от последнего бара в зоне VbP:IDn эти переменные с последующими/текущим High/Low бара для конечной точки линии спс. Date Time Of Last Edit: 2014-02-18 08:43:35
[2014-02-18 08:50:18] |
SC Support - закрепить за POC/VAH/VAL для VbP:IDn глобальные переменные
и как бы было здорово иметь доступ из ACSIL к этому динамическому массиву переменных, обращаясь к ID конкретного VbP либо по самому ID, либо по индексу баров, которые данный ID охватывает.спс. |
