Date/Time: Thu, 19 Nov 2026 13:09:27 +0000
ACSIL drawing vs subgraph efficiency
View Count: 1749
| [2019-11-08 16:54:34] |
| jmt816 - Posts: 45 |
About to start coding a custom study to draw horizontal lines at preset levels that repeat every 100 points. Each 100 point block would have about 20 lines. Am wondering which would be the more efficient way of doing this in ACSIL: drawing the lines or using subgraphs? I vaguely recalled seeing something somewhere in the documentation or support board, but was unable to locate this. Thanks in advance for your guidance! |
| [2019-11-10 06:00:28] |
Study Subgraphs are definitely much more efficient.
Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2019-11-10 06:00:33
