Date/Time: Fri, 03 May 2024 20:23:22 +0000
Running Sierra Charts on PC
View Count: 1023
[2019-11-07 18:17:10] |
Aditya Chopra - Posts: 21 |
Hi, At the moment I am running Sierra Charts on my laptop. I also wan to run it on PC in case of emergency. I downloaded Sierra on the PC, but unable to run it. I have entered the login details etc. I get the following message Connection error message from service ... DTC server program c:\SierraCart\Rim\DTCBridge.exe Also can I transfer my templates and chart setting to the PC. Thanks and regards Aditya |
[2019-11-08 02:04:31] |
Rerun the installation on your computer again by selecting Help >> Download Current Version, and when you get the initial installation window, be sure to check the option for Install Optional Components. This will install the missing program. Refer to the following documentation for how to transfer files between installations: Transferring Sierra Chart Settings and Data From Existing Installation to New Installation Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
