Date/Time: Fri, 03 May 2024 08:46:54 +0000
Horizontal Grid Offset with Trading Chart DOM On
View Count: 641
[2019-11-07 01:56:06] |
User17394 - Posts: 8 |
The right hand scale normally aligns perfectly with the horizontal grid but when the Trading Chart DOM is set to On then there is an offset. I have drawn a horizontal line at 56.50 to highlight the offset. Refer to the 2 images without and with the Trading Chart DOM. This makes it difficult to align the price when placing an order. Is there a way to remove the offset with the Trading Chart DOM On? http://www.sierrachart.com/image.php?Image=1573091576463.png http://www.sierrachart.com/image.php?Image=1573091645664.png |
[2019-11-08 01:18:15] |
You need to disable this option: Global Trade Settings Windows: Extend Chart Horizontal Grid onto Chart DOM (Global Settings >> Chart DOM Settings >> Other >> Other Settings) Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
