Date/Time: Sun, 19 May 2024 04:55:58 +0000
Ver 2005 - LG 5K2K Monitor - Anyone with 4K Monitor?
View Count: 1058
[2019-11-06 16:03:09] |
NRGTrader - Posts: 351 |
Upgraded to 5K2K monitor. I have all sizes set mostly how want and found all menu options in SC as well as Windows 10 to change settings (fonts, etc). However, I have not discovered how I can make candlestick bars wider. Much too narrow - almost looks like OHLC bar. I've used the toolbar to decrease date range, but then not enough data showing. How can I increase bar width and width between bars - maybe that will correct. Agny suggestions fro those of you using 4K or great monitors would be appreciated. Thanks |
[2019-11-06 16:34:05] |
The setting is: Global Settings >> Graphics Settings >> Other >> Candlestick Width %. Refer to: Graphics Settings Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2019-11-06 16:42:36] |
Yes I had found that setting, but set at 100% and still too narrow. I guess it's just nature of his def. Only other option is reduced resolution or increase scaling in windows.
[2019-11-06 23:58:54] |
Does not make sense to us. Post an image of the chart.
