Date/Time: Sun, 19 May 2024 11:05:50 +0000
Number bars calculated value 2007 - not in package
View Count: 542
[2019-11-06 07:43:16] |
User33743 - Posts: 83 |
Hello, I was using v. 1941 where Number bars calculated value study works, than i go into 2007v and i got msg Number bars calculated value - "Current servcie package doesn't not support this funkction". I am using Level 3. Could you help? Date Time Of Last Edit: 2019-11-06 13:07:55
[2019-11-06 23:32:41] |
You need to post to this support board from your active account. Otherwise, we will be unable to help you. To do this select Help >> Support Board from within Sierra Chart. This study is only supported on the Advanced Sierra Chart service package. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2019-11-06 23:36:45
