Date/Time: Thu, 02 May 2024 06:24:52 +0000
questions on DOM/market depth
View Count: 2001
[2019-11-05 20:24:20] |
User183272 - Posts: 13 |
1. http://www.sierrachart.com/image.php?Image=157298420690.png 2. http://www.sierrachart.com/image.php?Image=1572984293204.png 3. http://www.sierrachart.com/image.php?Image=157298452398.png Hello, questions regarding my DOM and chart 1. essentially I would like image 3 from my actual DOM, (with total volume traded from bid and ask, market depth, with recent transactions at the bid or ask) essentially to replace my first two images of the DOM I placed on numbers bar chart. How would I do that? Can I just copy verbatim what's on my trading dom to my chart? 2. Can I have the background of the numbers study one color (black) while the DOM on my chart another background color? How would I do that? 3. Regarding market depth of seeing more than one level for market depth....is there any way to have other levels show? as of now the market depth will display a number for example 2...can I switch it to hundreds instead? time and sales will show 200 for example and the market depth will show 200, I'd like to synch them ideally. Thank you, Date Time Of Last Edit: 2019-11-06 23:19:13
[2019-11-06 23:19:00] |
1. Yes, you will just copy the setup from the Trading DOM to the Chart DOM: Global Trade Settings Windows: Customize Chart/Trade DOM Columns (Chart Specific) It looks like you have most of it, the only piece that looks like it is missing is a Volume by Price profile that is Far Right Aligned that displays the Bid and Ask volumes. Refer to the following setting: Volume By Price Study: Align to Far Right 2. This is not fully supported. There is the ability to change the background for the Bid, Ask, Buy, and/or Sell columns, but those are the only ones. Refer to the following: Customizing Fonts, Colors, Line Styles, and Widths for Chart Trading, Chart DOM, and Trade DOM: Chart DOM Buy Column Background 3. The U.S. Equities exchange through the Sierra Chart Exchange Data Feed does not include market depth data. time and sales will show 200 200 what? The bid and ask size/quantity data is consistent between the market depth displays and the best bid and ask display. You can clearly see that in the first chart you posted.Also, we see that you are signed up for both the Denali Exchange Data Feed and the Sierra Chart Exchange Data Feed. If you continue to get the U.S. Equities from us, then you will want to discontinue use of the Denali feed and instead just use the Sierra Chart feed, by enabling the CME Exchange on the Sierra Chart feed. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2019-11-06 23:19:50
[2019-11-08 19:18:32] |
Hello, For full market data on equities, can i just subscripe to sierra chart software package and get the data feed from somewhere else to plat on my saved charts in sierra? For example open an account somewhere else, and link that account through the sc connection services to that platform? I believe you have a list of places where that data is available Same thing with futures? Do i have to subscribe to the denali feed to get real time data for futures? Can i link a tdameritrade account of another brokerage? |
[2019-11-10 05:53:21] |
For full market data on equities, can i just subscripe to sierra chart software package and get the data feed from somewhere else to plat on my saved charts in sierra? You could have a look at using Interactive Brokers for this data:Interactive Brokers Trading Service Assuming you are referring to market depth data? Same thing with futures? Do i have to subscribe to the denali feed to get real time data for futures?
Yes you definitely do for a good data feed.
Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2019-11-10 05:53:48
