Date/Time: Wed, 04 Nov 2026 16:19:04 +0000
How do you change the font size for horizontal line price value on Sierra Chart
View Count: 3371
| [2019-11-03 21:40:40] |
| Jay Greenlees - Posts: 15 |
| [2019-11-04 03:34:51] |
Refer to: Chart Drawing Tools: Changing the Font Size For Text Displayed with Tool Drawings (Global Chart Drawing Font) Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
| [2021-01-04 17:14:21] |
| yellowandy - Posts: 20 |
When I try this it says "Global Chart Drawing Font (Read Only)" and I'm unable to change the font. I'm trying to modify the horizontal ray text as it's unreadable at the moment. Thanks!
| [2021-01-04 18:40:17] |
| John - SC Support - Posts: 48419 |
Sorry, that is due to the layout of the new windows. That line is showing you what font you currently have selected. You need to select the item just below it in order to change the font (where it states (Button)). Click on the right side where it states [Select Global Chart Drawing Font] and then make changes on the page that comes up after that.
