Date/Time: Sat, 04 May 2024 18:27:47 +0000
chart
View Count: 997
[2013-12-19 19:28:46] |
Ed Meckelborg - Posts: 71 |
in some charts the display is all in the top half. How do I get it to display on the entire page?
[2013-12-19 19:32:41] |
Refer to this page: http://www.sierrachart.com/index.php?l=doc/helpdetails46.html Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2013-12-19 20:56:59] |
Sawtooth - Posts: 3993 |
Another possible solution: Set the Scale of all Region 1 studies to Same as Region.
