Date/Time: Sat, 18 May 2024 16:55:00 +0000
[Programming Help] - CurrentDate Time Trouble
View Count: 674
[2019-11-02 17:03:03] |
User312841 - Posts: 25 |
Seems like this should be an easy answer for a real programmer, I have not been able to find the answer. I want to put a marker (horizontal line in this case) at the same time each day. But it only displays on the chart in the most recent day. I tried persistent variables and in this example a global variable. Graph shows it working for the current day, what is the code to make it display in previous days. Thanks // Data processing sc.DataStartIndex = 0; SCDateTime TimeToCheckFor; //The first step is to get the current date. int CurrentDate = sc.BaseDateTimeIn[sc.ArraySize - 1].GetDate(); //Apply the time. For this example we will use 12 PM TimeToCheckFor.SetDate(CurrentDate); TimeToCheckFor.SetTimeHMS(12, 0, 0); //float LineVal = sc.Input[0].GetFloat(); // get integer value from Input 0 // TimeToCheckFor is contained within the current bar. if (sc.IsDateTimeContainedInBarIndex(TimeToCheckFor, sc.Index)) { g_highNoon = sc.RoundToTickSize(sc.BaseDataIn[SC_HIGH][sc.Index]+.00,0.01); } sc.Subgraph[0][sc.Index] = g_highNoon; } http://www.sierrachart.com/image.php?Image=1572713613953.png |
[2019-11-03 16:27:39] |
You can close this issue, I found a work around, and a realization that ASCIL programming is a much steeper climb than I naively thought.
