Date/Time: Sat, 18 May 2024 15:56:57 +0000
Feature Request: Link Time Zone to Chart Linking / Session Times.
View Count: 514
[2019-10-30 08:12:59] |
ycomp - Posts: 277 |
Link Time Zone to Chart Linking / Session Times. I think this would make sense since session times are irrelevant when the wrong time zone is being used on the chart. I mean if you link session times on 2 charts then when it is applied to the other chart, the time zone would be changed as well to be the same as that of the source chart. |
[2019-11-03 20:13:58] |
T44 - Posts: 363 |
You can already set the time zone in the symbol configuration which seems to make the most sense.
[2019-11-03 20:16:05] |
T44 - Posts: 363 |
If you are frequently changing symbols in a chart and want to update other settings, then an ASCIL study can work well - have it change the settings based on the value of sc.Symbol e.g. int IsES; IsES = sc.Symbol.CompareNoCase("ES",2); if (IsES == 0) { sc.StartTime1 = HMS_TIME(8,30,00); sc.EndTime1 = HMS_TIME(14,59,59); sc.StartTime2 = HMS_TIME(15,0,0); sc.EndTime2 = HMS_TIME(8,29,29); } |
