Date/Time: Sat, 04 May 2024 10:21:44 +0000
How to have trades info stay on chart?
View Count: 2034
[2013-04-12 02:22:25] |
madra - Posts: 109 |
Hello, I believe that I have seen this on some sierra charts: After a trade has been completed is it possible to have win or loss info remain on the chart? Thank you charlie |
[2013-04-12 02:27:28] |
Really you should look at the Trades tab of the Trade Activity Log for this: http://www.sierrachart.com/index.php?l=doc/doc_TradeActivityLog.php#TradesTab Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2013-04-12 02:35:53] |
Actually, there is a way. You can look at the Order Fills and display the PL: http://www.sierrachart.com/index.php?l=doc/doc_ChartTrading.html#DisplayingOrderFills Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
