Date/Time: Sat, 04 May 2024 19:33:10 +0000
About Renko Chart
View Count: 1087
[2013-12-18 15:38:37] |
fobglobal - Posts: 51 |
Hi If I have a renko chart with 3 ticks, using bricks everything looks ok, I mean all bricks are 3 ticks bar size, but if I change the chart to OHLC Bars then many times the bar size of many bars are lower than 3 (2 or 1). Why is that? Please let me know if that is correct or something is wrong. Thanks |
[2013-12-18 18:40:05] |
Please refer to this page: http://www.sierrachart.com/index.php?l=doc/doc_RenkoCharts.html Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
