Date/Time: Wed, 15 May 2024 12:56:46 +0000
Bar end time in
View Count: 748
[2019-10-24 21:22:23] |
User202286 - Posts: 2 |
Hello, How can I have the bar end time show up in my chart values for tools? I have SC installed on two pc's, on one it has both the start and end times, and on the other only the start time... Thanks in advance! |
[2019-10-27 14:53:27] |
You need to use this study for this: Bar End Time Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2019-10-29 02:28:02] |
Hi, The chart which shows the bar end time in the "Chart Values For Tools" does NOT have the Bar End Time study applied. It seems to be showing natively, as it shows up right under the bar begin time, before region 1. |
[2019-10-29 07:37:52] |
You will see this in the case of an Intraday chart.
Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2019-10-29 07:38:02
