Date/Time: Sat, 18 May 2024 06:48:40 +0000
[Programming Help] - Data/Trade Service Settings For BitMEX Accessable by ACSIL
View Count: 627
[2019-10-23 00:03:31] |
User36703 - Posts: 29 |
Dear Support, I would like to ask you if it is possible to get access to Service Settings via ACSIL. I need this for my autotrading algorithm to get access to Leverage Settings at least. We have got some options to get access there for usual settings, but I was not able to find anything particular for this matter. Please can you build some function for reading or adjusting the settings there? It will be very appreciated! |
BitMEX Trading Setting.png / V - Attached On 2019-10-23 00:02:31 UTC - Size: 32 KB - 235 views |
[2019-11-10 22:00:15] |
Please, any uptade from the support?
[2019-11-11 03:11:45] |
No, this is not supported and will not be.
[2019-11-11 13:29:25] |
It is a pitty because otherwise you would be a leading trading platform in case of crypto futures trading. Traders could check and control their leverage against liquidation price of BitMEX trading system direclty in Sierra Chart. Is it possible to do it outside ACSIL?
