Date/Time: Sat, 18 May 2024 04:05:29 +0000
Spikes on the Depth Chart after 1940 with CQG
View Count: 649
[2019-10-22 21:51:10] |
User194343 - Posts: 24 |
Dear Sierra! After 1940 my depth bar charts have some spikes... after 10.05 i can use only 1938 and newer with CQG, but from today, 1940 not working too! 1997 - ok, but after 1940 i have a spikes! Please, help!!! If i will delete all market depth data, sierrachart will reload it with spikes again. It's not my side disconnection problem... Date Time Of Last Edit: 2019-10-22 21:53:12
normal.jpg / V - Attached On 2019-10-22 21:48:08 UTC - Size: 107.23 KB - 299 views spikes.jpg / V - Attached On 2019-10-22 21:48:13 UTC - Size: 108.85 KB - 314 views |
[2019-10-22 23:01:22] |
Refer to this section here for this: CQG Trading Platform Service: CQG Market Depth Data Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
