Date/Time: Mon, 29 Apr 2024 04:12:32 +0000
Shifting Numbers Bars away from Vol by Price on Same Chart
View Count: 2303
[2013-04-12 02:17:23] |
absorrel4 - Posts: 92 |
I am placing the Numbers Bars and Vol by Price on the same chart....but I don't want them to overlap. Is there a way to shift the Numbers Bars to the left so that they no longer overlap with the Vol Profile that I place on the right side of the chart (see my attachment for what I am talking about). I tried to use the "Displacement" within each study...but that didn't work. Any ideas? Thanks...
Attachment Deleted. Numbers Bars overlapping Vol Profile.jpg / V - Attached On 2013-04-12 02:16:24 UTC - Size: 225.23 KB - 980 views |
[2013-04-12 02:25:15] |
Yes of course. Refer to Right Side Fill Space: http://www.sierrachart.com/index.php?l=doc/doc_WorkingWithCharts.html#ScrollingTheChart Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2013-04-12 03:06:46] |
No...that doesn't really do what I need....please see the attached Example...the vol by price study will create the profile on top of the price (or number bar) and simply shifts with the price when I create the blank fill space. I can scroll everything to the left and create a ton of right side fill space, but the vol by price study simply scrolls along with the price/numbers bars. I need the Vol by Price study to stay plotting on the right side of the chart in the empty fill space...and not be on top of the price/number bars. See the attached.
Example.jpg / V - Attached On 2013-04-12 03:05:18 UTC - Size: 171.57 KB - 760 views |
[2013-04-12 05:34:56] |
ganz - Posts: 1048 |
absorrel4, hi Try to set proper settings for Right Aligning http://www.sierrachart.com/index.php?l=doc/doc_VolumeByPrice.html#RightAligning gd lck |
