Date/Time: Sat, 18 May 2024 12:27:30 +0000
Disable DOM mouse click trading keeping keyboard trading enabled
View Count: 1587
[2019-10-21 13:04:26] |
ycomp - Posts: 277 |
Is there a way to disable DOM click trading but still allow keyboard trading (without confirmation) ? other than changing what each click does in Chart DOM Settings - Global ?
[2019-10-21 14:43:42] |
Yes just simply uncheck Trade >>Trading Chart DOM On.
[2019-10-22 03:08:45] |
T44 - Posts: 363 |
Trading Chart DOM On (Trade menu)
This option is always enabled for a dedicated Trading DOM window. ycomp, I too would appreciate this feature, it is easier to make an order entry mistake with the mouse vs the keyboard (especially a programmed keyboard) I've often wondered why the order entry windows don't support a quantity of zero. I could set this to be the default and then call a change quantity keyboard shortcut, do the keyboard trade, and then re-set quantity to zero in a single macro action. This would stop any accidental mouse clicks. |
[2019-11-10 12:33:55] |
T44 - Posts: 363 |
Enable all confirmations for the actions you want rejected (e.g. order place by mouse). Then run this Autohotkey (*.ahk) script to automatically reject those confirmation windows. Keyboard trading and Auto trading will be unaffected as they are controlled elsewhere. #Persistent
#SingleInstance Force SetTitleMatchMode, 1 SetTimer, CheckWin, 50 ;inefficient CheckWin: IfWinExist, Confirm Order { Blockinput, On WinWaitActive, Confirm Order SendInput, n Blockinput, Off return } IfWinExist, Cancel Confirmation { Blockinput, On WinWaitActive, Cancel Confirmation SendInput, n Blockinput, Off return } return Date Time Of Last Edit: 2019-11-10 12:34:48
