Date/Time: Sat, 04 May 2024 19:45:49 +0000
Custom study 32bit to 64bit
View Count: 745
[2019-10-19 10:32:15] |
User33743 - Posts: 83 |
Hello, I've read about sierra moving only to 64bit. How to run my 32bit custom dll into 64bit? What should i do? Do i need to change all code for dlls now so it works on 64bit? Best regards |
[2019-10-19 11:09:15] |
Ackin - Posts: 1865 |
Change source code no, just recompiled to 64bit form (Analysis >> Build Custom Studies DLL to make a 64 bit DLL.) Difference between 32/64-Bit: Software Download: Difference Between 32 and 64-bit Versions Date Time Of Last Edit: 2019-10-19 11:16:13
[2019-10-19 12:17:33] |
You just simply run the 64-bit Sierra Chart, and build the studies under that version. Refer to: How to Build an Advanced Custom Study from Source Code Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
