Date/Time: Thu, 02 May 2024 08:38:10 +0000
customize study based on ECIVwap
View Count: 789
[2019-10-18 05:24:19] |
Frank Ace - Posts: 12 |
Is it possible to do customized coding adjustment based on ECIVwap which cannot be done within settings?
Date Time Of Last Edit: 2019-10-18 06:16:57
[2019-10-21 21:22:19] |
Yes you can modify the code if you have it. Refer to: How to Build an Advanced Custom Study from Source Code Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2019-10-22 05:17:03] |
Thank you for the reference but after I searched all the studies files, I can only find code of Volume Weighted Average Price in Studies3.cpp file. Can you help me to locate the code of customer study ECIVwap 1.4? |
[2019-10-22 05:27:06] |
User90125 - Posts: 715 |
Try this: https://www.sierrachart.com/AdditionalFiles/UserContributedACS_SourceCode/ECIVwap.cpp
