Date/Time: Wed, 08 May 2024 05:33:10 +0000
Point & Figure Chart as OHLC Bar Chart
View Count: 774
[2019-10-18 04:02:26] |
User788855 - Posts: 8 |
Hi, Market delta provides it's users the option to plot Point & Figure Charts as to show in OHLC bar charts , even Ninja Trader allows it by plotting two charts as overlay . Is there any way in Sierra charts to do that ? Thank you ! Date Time Of Last Edit: 2019-10-18 04:03:18
[2019-10-18 07:17:20] |
Yes. You need to change the Graph Draw Type: Chart Settings: Graph Draw Type (Chart >> Chart Settings >> Bar Period >> Graph Draw Type menu) Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2019-10-18 07:18:20
