Date/Time: Wed, 15 May 2024 08:11:30 +0000
Global sound mute
View Count: 1464
[2013-12-17 17:02:55] |
imdtrader - Posts: 26 |
Is there an option to mute globally all the sounds from Sierra? I know I can turn off sound on my computer, but it is not an options in this case. I need sound from other applications, but not from SierraChart in some occasions. Thank you. |
[2013-12-17 17:07:59] |
Sierra Chart - Max - Posts: 5610 |
As you can see here: http://www.thewindowsclub.com/the-new-windows-7-volume-mixer-control The sound Mixer under windows will allow you to control the volume on a per application basis. So you can mute Sierra Chart and allow other applications to have sound. Sierra Chart Support |
[2018-04-25 14:02:21] |
Bedhog - Posts: 168 |
Can we please have a Mute Chart setting? I use a Control Bar with AutoTradingGlobal and AutoTradingChart which is great. It would be just as great to have 2 buttons on a Control Bar that work the same way for sound MuteGlobal and MuteChart Thank you. |
