Date/Time: Thu, 02 May 2024 22:07:25 +0000
Do you have Indian Data Feed
View Count: 901
[2019-10-17 00:53:48] |
User279714 - Posts: 21 |
Currently do you have any working Indian Data Feed. Is Globaldatafeed (GDFL) or Esignal compatible with the software. Regards |
[2019-10-17 19:44:17] |
Global Data Feeds is now supported but we still have to prepare a documentation page for it. But they have already prepared some documentation. Go to their website and look for support for Sierra Chart: Http://www.globaldatafeeds.in Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2019-10-17 19:45:00
[2020-05-20 06:24:50] |
Does your data feed work with Sierra Chart? Does it support the DTC Protocol like Global Data Feeds?
Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2020-05-20 06:25:08
