Date/Time: Sun, 05 May 2024 16:38:40 +0000
[User Discussion] - Break Even to Trail (Simultaneously While in One Order)
View Count: 920
[2019-10-17 00:31:57] |
User355317 - Posts: 10 |
Hi I would like to know how I can, both, have a stop automatically go to break even after 10 ticks and also then, have that same stopped line begin to trail price after it passes another 10 ticks, and then again after every other 10th tick thereafter, and have that happen indefinitely. Or can I somehow create an automatic break even stop after every 10th tick price passes? Thanks. |
[2019-10-17 19:49:08] |
You need to use a combination of the Move to Breakeven for Stop setting: Attached Orders: Move to Breakeven for Stop And also a Triggered Trailing Stop: Order Types: Triggered Trailing Stop But this is only going to give you two price points to do triggering and a set of behavior for each. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
