Date/Time: Sat, 27 Apr 2024 23:49:35 +0000
subtle differences in IB charts and Sierra charts, although using IB data feed!
View Count: 1152
[2013-12-17 09:12:01] |
User59879 - Posts: 66 |
I am using Sierra with IB data from my IB/TWS, and have noticed some subtle differences in charts drawn by IB and charts drawn by Sierra. Sometimes the Open or Close in a bar are different between the two charts, resulting in a slightly different candle, for example a small green candle in the Sierra chart and a Doji in the same candle in IB ... I have been looking for configuration options, but have not found anything that can explain the difference. Same data, different chart! How is this possible and what is going on? |
[2013-12-17 19:32:20] |
This question is not within the scope of our support. If you are trading futures, we recommend using the Sierra Chart futures data feed: http://www.sierrachart.com/index.php?l=doc/SierraChartRealTimeFuturesStockDataFeed.php Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
