Date/Time: Tue, 07 May 2024 12:15:20 +0000
Tick Chart Help
View Count: 1031
[2019-10-14 03:12:49] |
User642945 - Posts: 9 |
Hello, I am currently trying to build a chart for the Micro ES that is a 900 tick chart with a heiken ashi smoothed for the candles When I change the chart to 900 trades per bar that works fine...but when I decide to add the heiken asi smoothed it changes the current price on the chart For example before I added the heiken ashi candles the price of ES was 2976 but once i added those candles it is now saying the current price is 2 points lower than what it actually is...How do I fix this? Thank you Ive added pictures of my chart settings and heiken settings |
Screen Shot 2019-10-13 at 11.10.20 PM.png / V - Attached On 2019-10-14 03:10:51 UTC - Size: 36.42 KB - 327 views Attachment Deleted. Screen Shot 2019-10-13 at 11.07.37 PM.png / V - Attached On 2019-10-14 03:11:08 UTC - Size: 115.45 KB - 298 views |
[2019-10-14 10:40:06] |
The answer is quite simple. Just do not use the Heikin Ashi Smoothed study. It will alter the prices of the bars.
