Date/Time: Tue, 07 May 2024 08:17:21 +0000
Volume Profile Tool
View Count: 621
[2019-10-12 13:24:28] |
RIFT - Posts: 124 |
Can you please create a volume profile tool, where on one side the total volume, on the other side the ask vol. - bid vol is. Thanks! |
2019-10-12_15h15_02.png / V - Attached On 2019-10-12 13:24:03 UTC - Size: 339.43 KB - 489 views |
[2019-10-12 13:32:37] |
RIFT - Posts: 124 |
The best would be with an Anchor VWAP from high and from low. :) Thanks! |
Attachment Deleted. 2019-10-12_15h28_49.png / V - Attached On 2019-10-12 13:31:59 UTC - Size: 312.63 KB - 459 views |
[2019-10-12 15:49:09] |
John - SC Support - Posts: 31419 |
We cannot add anything new now. You would be waiting years. You need to instead look at this setting: Volume By Price Study: Bid Volume and Ask Volume Coloring Method For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2019-10-12 18:25:50
