Date/Time: Fri, 03 May 2024 21:12:01 +0000
DOM Setup
View Count: 1720
[2013-12-17 02:25:34] |
User40667 - Posts: 1 |
Hi could you please help me with setting up the DOM, I'm connected to CTS. 1. The PnL display for an open trade shows the total pnl for all contracts, can it be changed to show pnl per contract? 2. How to move the volume profile to the far right of DOM ? 3. There is no confirmation required when placing new trade but when I adjust the child orders after entry I need to confirm, how do I disable that? 4. I have the ES showing in the DOM it does not show the decimal point, is there a way to make it show? and is there a way to bold the last few digits and make it larger font? For example instead of 177875 can it show 1778.75 (with the bold chars one size larger would be even better) to make it easier to pick out. Thanks http://www.sierrachart.com/image.php?l=1387246664500.png |
[2013-12-17 22:34:34] |
1. You need to set the Position Profit/Loss setting: http://www.sierrachart.com/index.php?l=doc/doc_ChartSettings.html#ProfitLossDisplay 2. This is not supported. But you can change the alignment from the left side of the trade DOM over to the right side but still to the left of the Order columns and price scale. Set the Right Align Volume Bars input with the Volume by Price study to Yes. 3. Refer to: http://www.sierrachart.com/index.php?l=doc/doc_TradeWindow.html#MenuButton 4. Update Sierra Chart to the latest version (Help >> Download Current Version) and refer to the information here: http://www.sierrachart.com/index.php?l=doc/CTS_T4.php#UsingFIX The bolding of the price like you are asking for is not supported. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2013-12-17 22:34:53
