Date/Time: Sun, 05 May 2024 06:10:25 +0000
BreakEven Stop
View Count: 1658
[2019-10-11 15:35:00] |
User244709 - Posts: 3 |
Hello, Can you tell me how i need to put in the following order? I want a breakeven stop from the moment i reach 30 points profit. From then on, i want a trailing stop of 1 point. So it's a combination of a breakeven stop with a trailing stop. example: long spx fut at 2900 when 2930 then automatically a breakeven stop and the start of a trailing stop of 1 point. so when spx fut = 2933 the stop should be 2903 and so on |
[2019-10-12 15:37:55] |
John - SC Support - Posts: 31362 |
You would want to use a Triggered Trail Stop for the Attached Order with the Trigger Offset and the Trail Offset to 30 points. Refer to the following: Order Types: Triggered Trailing Stop For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2021-12-18 15:01:40] |
User837393 - Posts: 132 |
I was looking for something similar. Do we have to fill the « Move to breakeven » part of chart trade window, or does all that can happend with the trigger function of the triggered trailing stop ?
Date Time Of Last Edit: 2021-12-18 15:02:26
[2021-12-20 03:50:37] |
It depends what exactly you want to do. Here is the documentation for Move to Breakeven for Stop: Attached Orders: Move to Breakeven for Stop Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
