Date/Time: Wed, 01 May 2024 18:57:57 +0000
Global Curson On
View Count: 557
[2019-10-11 10:54:25] |
SkyKeeper - Posts: 39 |
Is it possible to make the global cursor if the crosshair comes out of the chart be removed automatically from all the charts
[2019-10-13 16:56:42] |
Yes we will see if we can make that work.
[2019-10-16 21:53:12] |
This is now supported in the latest prerelease which is 1999.
[2019-10-17 02:40:57] |
Thank The best platform is SierraChart |
