Date/Time: Sun, 05 May 2024 01:27:08 +0000
Feature request........... Yes, I know but if you guys could just read it, please.
View Count: 693
[2019-10-10 17:31:10] |
Mattthespaniard - Posts: 41 |
I have been a long term indirect customer through Transact and since last month a very happy direct one of your Futures Order Routing through TT. The change is absolutely worth it. Thanks. 3 years ago I made the following request: I would like to suggest the addition ( or modification of an existing ) tool. Sometimes a move in the market is caused by a very specific piece of news. I miss having the possibility of attaching a small marker to the chart which when clicked upon opens an editable text window where I could input a few lines explaining the situation. The current text tool is not suitable for such purpose for it clogs the chart very quickly with text that I don't necessarily want to have this text visible at all times, but only when I click on the marker. Such a tool would make my life WAY EASIER with keeping market reports handily linked to the instrument I'm trading. I would appreciate if your development team could consider adding this feature in the builds to come. The engineering team replied that "something like that will eventually come" and until now... Now I'm begging for this tool to be implemented. Surely it can't be that difficult for you guys ( if it is, pardon my ignorance re coding ). Also, I plot Commitments of Traders data using your spreadsheet feature and it works fine but there is a nagging problem: if only I could plot each instrument's weekly price data starting on Wednesday and ending on Tuesday so as to coincide with COT release time frames ! Can this be implemented or maybe I'm asking for too much ? In any case, I don't want to miss the opportunity to thank you all for the wonderful piece of software Sierra Chart is. |
[2019-10-11 08:33:50] |
binaryduke - Posts: 360 |
Check out the commercial offering: www.verbaljournaltrading.com that's available for Sierra Chart.
[2019-10-14 07:15:50] |
We will look at modifying the Text tool with a new option which will support hidden text which can be viewed in some way. Maybe clicking on a square beside the visible text. Also, I plot Commitments of Traders data using your spreadsheet feature and it works fine but there is a nagging problem: if only I could plot each instrument's weekly price data starting on Wednesday and ending on Tuesday so as to coincide with COT release time frames ! Can this be implemented or maybe I'm asking for too much ? Really you just need to create a custom study to accomplish this: Advanced Custom Study Interface and Language (ACSIL) Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2019-10-14 09:19:57] |
In the next release we will support hidden text with the Text tool and then when you left click on the displayed "T" it will switch between hidden and non-hidden. This is just a very basic implementation which we hope should meet your needs.
