Date/Time: Wed, 08 May 2024 01:29:41 +0000
sychronize problem
View Count: 555
[2019-10-10 14:12:53] |
user - Posts: 77 |
I am comparing small DAX futures with big DAX futures, everything is normal except I find 2019Sep06, which does not sychronize. The small DAX futures lead big DAX futures by 15min. I have already deleted the data and redownloaded it, but problem is still here. attached please find the captured screen. |
Private File |
[2019-10-11 21:03:45] |
The problem would be related to the settings you have for the Study/Price Overlay. But given how you are displaying the information, it would be easier to use the Add Additional Symbol study instead. Refer to the following information: Add Additional Symbol Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
