Date/Time: Mon, 20 May 2024 05:47:09 +0000
[User Discussion] - fail to accessing market data from other instances of sierra chart
View Count: 536
[2019-10-10 03:58:27] |
This is not within the scope of our support. If you want to use data between instances use this feature only on the same computer: Using DTC Server for Data and Trading in Another Sierra Chart Instance If you are using this method here this is not something we provide any technical support for at all: https://www.sierrachart.com/index.php?page=doc/MultipleServices.html#AccessingMarketDataFromOtherInstancesOfSierra%20Chart That is for advanced users only and we just do not provide support for it. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
