Date/Time: Sun, 19 May 2024 21:13:35 +0000
ACSIL: Load Daily Bars Programmatically
View Count: 574
[2019-10-09 19:23:18] |
User41727 - Posts: 124 |
I have a study running on an intraday chart, and what I would like to do is load the corresponding daily bars for the respective symbol without having to open a separate daily chart to reference, as I only need the data once. I am essentially looking for an equivalent of the sc.ReadIntradayFileRecordForBarIndexAndSubIndex() function for daily data. Does something like this exist?
[2019-10-10 03:30:14] |
You can read the Historical Daily data text file directly: Text/CSV Data Format Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
