Date/Time: Mon, 20 May 2024 05:47:06 +0000
[Programming Help] - Indicator Support
View Count: 665
[2019-10-09 07:21:42] |
User688457 - Posts: 9 |
Dear Sierra Chart, I want to start off by saying that sierra chart is my platform of choice. But I have tried every variation and customization that i could to get a correct subcharting visual of a Volume-Weighted Accummulation/Distribution graph that is similar to the picture i attached. If possible, can u add it? Thanks in Advance Date Time Of Last Edit: 2019-10-09 07:22:49
Sierra_Chart__Image_1.png / V - Attached On 2019-10-09 07:22:19 UTC - Size: 41.01 KB - 255 views |
[2019-10-09 07:28:30] |
We are not understanding this. That chart shows the Volume Zone Oscillator. Specifically what is the question in regards to it? Did you not make that chart yourself and you want the study to look like that? Or did you make it and therefore what is the question?
[2019-10-09 10:36:34] |
Actually we see the study in the chart image is named "Volume Zone Oscillator Zero". The one in Sierra Chart is named "Volume Zone Oscillator". Not sure of the difference. Maybe just the Draw Style is different? Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2019-10-09 10:37:06
[2019-10-09 14:42:01] |
Thanks for the response, I was using that particular graph in my attachment as a example of the visual that i cant create with a Volume Weighted A/D, because there is no Volume Weighted A/D study. And the Accumulation/Distribution studies that are available, they have a different charting visual, and when i tried to make them look similar to the graph that i posted, it simply doesnt allow me to. The ideal study that i dont have or see or can create is the Volume Weighted AD that plots a similar graph as the Volume Zone Oscillator that i manually adjusted for an example to show you all. I attached another picture of how it should look. Please help, and i am not savy enough to program it myself, if i could then i would. Thanks. Date Time Of Last Edit: 2019-10-09 14:57:16
