Date/Time: Sun, 19 May 2024 17:52:29 +0000
I've got a 4k laptop and the numbers and buttons do not show up well.
View Count: 665
[2019-10-08 21:59:41] |
User425499 - Posts: 3 |
I was able to make the numbers more readable yet the panel is not easy to see in 4k. A 4k monitor is important for the video and photo work I do for clients. I really don't want to buy a separate computer and laptop. Are you currently working to make the sierra charts work with 4k laptops and monitors? |
[2019-10-09 08:14:14] |
You need to increase the text size. Refer to: Graphics Settings: Fonts and Text Appearance And refer to: Graphics Settings: Adjusting Size of Dialog Windows The dialog windows in Sierra Chart are going to be rebuilt and they will not have any operating system dependency as far as size goes and will be fully user adjustable. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2019-10-09 08:17:42
