Date/Time: Mon, 06 May 2024 11:06:12 +0000
OpenGL issue
View Count: 1333
[2019-10-08 12:42:25] |
User624750 - Posts: 27 |
Hello! I cant see charts (only frames of chart's windows) when I turn on OpenGL. If i click on chart window following messager appear: Triggering next historical data download in queue. | 2019-10-08 15:33:44.880 Socket (4) | Socket gracefully closed by remote side. | 2019-10-08 15:33:45.012 Socket (4) | Closed. | 2019-10-08 15:33:45.012 Opened cached Intraday file: C:\SierraChart\Data\GC-201912-NYMEX.scid | 2019-10-08 15:33:45.726 Opened cached Intraday file: C:\SierraChart\Data\EUR-201912-GLOBEX.scid | 2019-10-08 15:33:45.727 Opened cached Intraday file: C:\SierraChart\Data\ES-201912-GLOBEX.scid | 2019-10-08 15:33:45.729 CL-201911-NYMEX[M] 1 Min #1 | Caught an unhandled exception in c_Chart::WindowProc. Message: 513, wParam: 1, lParam: 6947498 | 2019-10-08 15:33:47.070 * Opened cached Intraday file: C:\SierraChart\Data\ZB-201912-ECBOT.scid | 2019-10-08 15:33:50.731 Opened cached Intraday file: C:\SierraChart\Data\CL-201911-NYMEX.scid | 2019-10-08 15:33:50.732 Opened cached Intraday file: C:\SierraChart\Data\HG-201912-NYMEX.scid | 2019-10-08 15:33:50.733 |
[2019-10-08 13:02:04] |
Detached chart's window work good! I have Nvidia Geforce GPU |
[2019-10-08 15:47:06] |
We may or may not be able to reproduce the problem. We need to get the Chartbook which is causing the problem. Follow these instructions: https://www.sierrachart.com/index.php?page=PostingInformation.php#AttachFile Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2019-10-09 11:02:34] |
We need to know if you are still encountering this exception when you disable the OpenGL option and restart Sierra Chart. Please let us know. It may be unrelated to OpenGL.
[2019-10-09 11:37:28] |
Hello! Chartbook is attached. All work propelly When I turn off OpenGL. I tested this few times. When OpenGL is on - I have problem, when off - no problem! Date Time Of Last Edit: 2019-10-09 13:42:31
Market Monitor - CL ES 6E GC ZB HG.Cht - Attached On 2019-10-09 11:32:14 UTC - Size: 352.95 KB - 310 views |
[2019-10-09 11:51:34] |
I have tested different Chartbooks, on different instances. I have the same prodblem: detached Chart work good, attached Charts - only window's frames!!! |
[2019-10-09 13:31:55] |
Thank you. We will be testing this.
[2019-10-16 08:13:53] |
AlexanderK - Posts: 290 |
Добрый день, у меня не получается воспроизвести проблему. Вы можете предоставить дополнительную информацию? 1. Пожалуйста установите GPU_Z: https://www.techpowerup.com/gpuz/ и пришлите скриншот первой страницы этого приложения. 2. Сколько мониторов и видео адаптеров у Вас установленно? 3. Какое разрешение экрана? Good day, I cannot reproduce your problem. Could you send me additional information please? 1. Please install GPU-Z from https://www.techpowerup.com/gpuz/ and send me screenshot of the first page in this app 2. How many video cards and displays do you have in your system? 3. What is screen resolution? |
[2019-10-16 13:37:52] |
1. Screenshot attached 2. GPU - 6, Monitors - 6 (2560x1440) 3. 2560x1440 for each monitor |
[2019-10-16 19:32:06] |
I am so sorry for misprint! I have 2 GPU, not 6! One GPU for 3 monitors! |
[2019-10-16 20:50:51] |
can you try to keep all windows on the same monitor where you run SierraChart, please?
[2019-10-18 13:51:27] |
Hello! Main window = MW; Attache window = AW Any monitor connected to GPU1 = M1, Any monitor connected to GPU2 = M2 1. If MW was closed on M2 then it will work good after new start, as will be opened on M2 1.1 After started - GPU2 usage for example 8-10%, GPU1 usage 1% (MW still on M2) 1.2 MW was be moved from M2 to M1 then GPU2 usage 30-35% and GPU1 usage 30-35%!!! 1.4 MW on M2 and AW on M2: GPU2-12%, GPU1 - 1%; 1.5 MW on M2 and AW on M1: GPU2-15%, GPU1 - 5% 2. If MW was closed on M1 then after new start I have only frames on MW, as it will be opened on M1. AW work OK. 2.1 After started GPU2 usage 1-2%, GPU1 usage 1-2% (still on M1) 2.2 If MW will be moved from M1 to M2 then will be the same situation - MW=Franes, AW=OK!!! 3. New issue - wrong rendering of Marker Tool if checked "Draw outline only (Hollow)" option. Check it please. The frame of this marker changes when scrolling chart, part of the frame diappear randomly! PS All indicated GPU usage was on equal load!!!!!!!!!! |
[2019-10-18 15:23:17] |
Correction in previuos post!!! I mean Detached window not Attached!!! Please change AW for DW!!! |
[2019-10-23 16:32:20] |
We will be doing some more testing in regards to this.
[2019-11-08 20:14:49] |
We want you to update to prerelease 2008 and test and see if you notice any improvement. Refer to: Software Download: Fast Update Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2019-11-08 20:14:58
[2019-11-13 13:39:20] |
Hello! Today I have tested v2009. Additionally I tryed to use Nvidia Control Panel. 1. Nvidia Control Panel\Manage 3D settings\OpenGL rendering GPU = Auto-Select - the same situation described in post #12 2. Nvidia Control Panel\Manage 3D settings\OpenGL rendering GPU = GPU1 2.1 No empty frames in any combinations 2.2 MW on M1 - GPU1 10%, GPU2 0-1% 2.3 MW on M2 - GPU1 30-35%, GPU2 30-35%!!! 2. Nvidia Control Panel\Manage 3D settings\OpenGL rendering GPU = GPU2 2.1 No empty frames in any combinations 2.2 MW on M2 - GPU1 10%, GPU2 0-1% 2.3 MW on M1 - GPU1 30-35%, GPU2 30-35%!!! In any case DW add resonable load to GPU1 if located on M1 or to GPU2 if located on M2 (does not matter which GPU is selected in Nvidia Control Panel) Now I have to select GPU (Nvidia Control Panel) and control manually that MW must be on monitor connected to selected GPU! In this case no GPU's overload and no empty frames! |
