Date/Time: Sat, 04 May 2024 00:13:49 +0000
Rithmic data feed issues??
View Count: 1661
[2019-10-07 21:48:17] |
deano129 - Posts: 3 |
Hi, im about to start a trading combine with oneuptrader, but i have heard a few stories saying that sierra chart is having issues with the connection to rithmic data feeds? is this true?
[2019-10-08 02:45:47] |
Do not use Rithmic. You are not going to get any technical help from us. Refer to: https://www.sierrachart.com/index.php?page=doc/Rithmic.php#TechnicalSupportPolicy Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
