Date/Time: Mon, 06 May 2024 00:10:36 +0000
problem with Intraday data
View Count: 1102
[2013-12-16 14:24:54] |
User73873 - Posts: 14 |
Hello, When I change the time frame, there are missing some data, the candles are false. See chart below. How can I fix the problem ? |
sierra cgart.JPG / V - Attached On 2013-12-16 14:23:02 UTC - Size: 196.51 KB - 359 views Attachment Deleted. |
[2013-12-16 16:27:32] |
What appears to be happening is that the rollover/transition from the January contract to the February contract is occurring near the end of the chart. What you can do is disable Chart >> Chart Settings >> Advanced Settings >> Continuous Futures Contract. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2013-12-16 16:27:51
[2013-12-17 14:28:45] |
There is a problem. I click on "continuous future contrat". When i change the timeframe, I need to "delete and download data" to have the chart with the correct data (see my second chart attache). I don't how can i fix this problem ! |
crude light continousJPG1.JPG / V - Attached On 2013-12-17 14:25:07 UTC - Size: 186.01 KB - 382 views crude light continousJPG.JPG / V - Attached On 2013-12-17 14:25:15 UTC - Size: 212.91 KB - 386 views |
