Date/Time: Sun, 28 Apr 2024 19:59:56 +0000
Moving the crossing point of two averages by changing only the compression of the graph
View Count: 758
[2019-10-04 17:08:33] |
bercor - Posts: 30 |
I kindly ask you if any person can explain to me why there is a problem with displaying a graph by enlarging or shrinking the window, maintaining the same temporal compression. I have traced the lower part of the image for example OBV (but it also happens with other indicators) with two averages as in the example, and I have vertical green line (to explain myself better) when two averages intersect. I then compressed the visualization without changing any setup with the key at the top and the averages were out of phase, that is, the intersection changed, moving forward by more bars as in drawing 2. I did not change any graph or averages. Thanks to those who will be able to help me. Hello |
Attachment Deleted. qqqqqq.JPG / V - Attached On 2019-10-04 17:07:45 UTC - Size: 206.58 KB - 265 views |
[2019-10-04 21:36:30] |
Most likely the scale settings are not the same for those two studies. Especially if one is set to Automatic and the other is set to Independent. Refer to the following: Chart Scale and Scale Adjusting: Maintaining Same Scale for Multiple Graphs in Chart Region Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2019-10-05 19:58:28] |
Thank you for your kind advice but the advice you gave me cannot be used because the cell is gray and not flaggable. I point out to you that I put three indicators under the graph and the problem subsists only on one. what should I do? thank you so much |
sierraxxx.png / V - Attached On 2019-10-05 19:56:40 UTC - Size: 178.63 KB - 251 views Attachment Deleted. |
[2019-10-06 02:03:09] |
X and Y constant relationship scaling is not relevant here. Do not use that. You want to use an Automatic Scale Range setting for all of the studies in the same region. The section we linked to is titled: Maintaining Same Scale for Multiple Graphs in Chart Region Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2019-10-07 18:07:59] |
Thank you for your kind reply and advice! I did what you told me and the problem persists. I am attaching three photos , What should I do? Thanks! |
triggert2.JPG / V - Attached On 2019-10-07 18:07:00 UTC - Size: 18.48 KB - 246 views trigger 1.JPG / V - Attached On 2019-10-07 18:07:11 UTC - Size: 16.05 KB - 246 views ok maintenance scale.JPG / V - Attached On 2019-10-07 18:07:26 UTC - Size: 66.72 KB - 265 views |
[2019-10-08 02:54:25] |
At this point further help is going to require that you obtain a paid Sierra Chart account. Follow these instructions to add usage time to your Sierra Chart account: 1. Select "Help >> Add Usage Credit" on the Sierra Chart software menu. You can also go to this page in your browser: https://www.sierrachart.com/UserControlPanel.php?page=ServicesActivation Login with your Sierra Chart Account Name and Password. 2. Choose the particular Service Package that you want to automatically renew and press the "Update" button. 3. Add sufficient credit to your Services Balance using any of the available payment options: https://www.sierrachart.com/UserControlPanel.php?page=AddAccountCredit For further information, refer to: Sierra Chart Purchase and License Information: Renewing Access ---- When you have paid for Sierra Chart let us know and then we will need to obtain your Chartbook and look into this. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
