Date/Time: Sun, 05 May 2024 21:15:51 +0000
Chart trade mode
View Count: 1262
[2013-12-16 01:38:06] |
sierra - Posts: 22 |
Trying to finaly learn how to trade from the chart trade mode. Trying first in sim. settings are 1. unchecked trade sim mode on 2. Show order fills 3. Show orders and positions When I go to place an order on Transact dom nothing shows on Sierra Charts even when filled and when I place an order on charts nothing shows up in the Transact dom Please advise |
[2013-12-16 01:43:33] |
How do you have Global Settings >> Data/Trade Service Settings >> Connection Type set?
[2013-12-16 01:51:02] |
Yes, At the time I had it on "live" and have since tried "simulated live" and still nothing |
[2013-12-16 01:56:31] |
And does the setting match to the setting you used when logging into the TransAct software? When you enter an order from the TransAct software do you see the order listed in Trade >> Trade Orders and Positions >> Orders? The generally is not much problem with this as long as the Connection Type setting matches what you use in the TransAct software. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2013-12-16 01:57:07
[2013-12-16 02:04:28] |
I logged in under live sim, so yes the settings matched. I have had this problem for 2 years and have traded stricktly off Transact Dom because I couldnt get it resolved. I would sure like to fix it now. Trade>> oreder and position >>orders is showing nothing as if I never placed an order. My version of Transact is 15.5.4 |
[2013-12-16 02:35:39] |
Closed connection and re opened. Everything is working now. Going to try live frading tomorrow and hope it works. Thanks for listening! Kurt |
