Date/Time: Wed, 15 May 2024 09:06:07 +0000
No data
View Count: 475
[2019-10-04 06:40:39] |
User275648 - Posts: 8 |
Hi, I've changed from Package 5 to package 3 this morning, and all of a sudden I am unable to connect to SC data feed. It is showing as not available for current package. Could you help please. Thanks |
[2019-10-04 08:05:03] |
Your Sierra Chart service package is still on 5. And your account is active. You are running an older version of Sierra Chart. Update: Software Download: Fast Update What Data or Trading service are you using or do you wish to use? See this page for the list: https://www.sierrachart.com/index.php?page=doc/Contents.php#SupportedDataAndTradingServices Or, select "Global Settings >> Data/Trade Service Settings". What is the "Service" at the top left set to? Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
