Date/Time: Tue, 14 May 2024 00:00:24 +0000
barchart data missing
View Count: 492
[2019-10-03 22:31:22] |
bskogz12 - Posts: 36 |
Is sierra charts no longer using barcharts? i dont see it in the drop down menu on the latest download
[2019-10-04 09:50:08] |
In newer versions it is not supported to connect directly to Barchart anymore. You need to use this service: Sierra Chart Exchange Data Feed Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
