Date/Time: Sat, 04 May 2024 11:58:06 +0000
Different File Nmes
View Count: 1022
[2013-12-15 22:44:29] |
Richard Reyes - Posts: 98 |
I was looking at the "Data" folder within the Sierra Charts folder and I noticed a lot of files but with different ending number sequences. There will be the same file name (GBPCHF or EURJPY or GBPJPY), but with different ending number sequences .175.cbak, .176.cbak, .177.cbak, .178.cbak and on and on. I am sure that each of these individual files (GBPCHF) is not the same. What is the difference and is there a difference? Many Thanks
[2013-12-16 07:57:42] |
These are backup Chartbook files and are documented here: http://www.sierrachart.com/index.php?l=doc/doc_Chartbooks.html#BackupChartbook Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
