Date/Time: Sat, 27 Apr 2024 21:50:49 +0000
External Data service Connection Issue
View Count: 1141
[2013-12-15 10:03:28] |
100 - Posts: 147 |
Software version: 1061 | 2013-12-15 04:39:42 Usage end date: 2013-12-23 | 2013-12-15 04:39:42 Enabled for: Sierra Chart Historical Data Service. | 2013-12-15 04:39:42 Active service: Rithmic 01 | 2013-12-15 04:39:42 Time Zone: -05:00:00 (EST-05EDT+01,M3.2.0/02:00,M11.1.0/02:00) | 2013-12-15 04:39:42 2013-12-15 04:39:42 Local computer clock time | 2013-12-15 04:39:42 2013-12-15 09:39:42 GMT time | 2013-12-15 04:39:42 2013-12-15 04:39:42 Time zone adjusted time | 2013-12-15 04:39:42 Time difference to server time: 11 seconds. | 2013-12-15 04:39:42 Program path: C:\SierraChart\ | 2013-12-15 04:39:42 Data Files path: C:\SierraChart\Data\ | 2013-12-15 04:39:42 OS Version Number: 6.1 | 2013-12-15 04:39:42 Checking for new symbol settings for rim | 2013-12-15 04:39:42 Rithmic 01 - Port for executable: 24513 | 2013-12-15 04:39:47 Rithmic 01 - Starting server: C:\SierraChart\Rim\GSPBridge.exe | 2013-12-15 04:39:47 Rithmic 01: Connecting to the server 127.0.0.1. Port 24513 | 2013-12-15 04:39:48 The network socket is connected. | 2013-12-15 04:39:48 Rithmic 01: Connected to server. | 2013-12-15 04:39:48 Rithmic 01: Sending logon request message. | 2013-12-15 04:39:48 Rithmic 01 - Starting the connection process to data and trading service. | 2013-12-15 04:39:48 Rithmic 01 - Logging is enabled. Log file: Rithmic.log | 2013-12-15 04:39:48 Rithmic 01 - Connecting to Rithmic 01 US server. | 2013-12-15 04:39:48 Rithmic 01 - Server Alert: Market Data Connection Broken. Error text: | 2013-12-15 04:39:50 Rithmic 01 - Server Alert: Trading System Connection Broken. Error text: | 2013-12-15 04:39:50 Rithmic 01 - Server Alert: PnL Connection Broken. Error text: | 2013-12-15 04:39:50 Rithmic 01 - Server Alert: Intraday History Connection Broken. Error text: | 2013-12-15 04:39:50 A request for the latest software update has been made. | 2013-12-15 04:40:37 The update is being downloaded in the background. When it is complete, you will be prompted. | 2013-12-15 04:40:37 There is no new version available. Thank you. | 2013-12-15 04:40:37 File >> Disconnect selected. | 2013-12-15 04:41:02 Rithmic 01: Disconnected from the server. | 2013-12-15 04:41:02 Rithmic 01 - Port for executable: 38849 | 2013-12-15 04:41:04 Rithmic 01 - Starting server: C:\SierraChart\Rim\GSPBridge.exe | 2013-12-15 04:41:04 Rithmic 01: Connecting to the server 127.0.0.1. Port 38849 | 2013-12-15 04:41:05 The network socket is connected. | 2013-12-15 04:41:05 Rithmic 01: Connected to server. | 2013-12-15 04:41:05 Rithmic 01: Sending logon request message. | 2013-12-15 04:41:05 Rithmic 01 - Starting the connection process to data and trading service. | 2013-12-15 04:41:05 Rithmic 01 - Logging is enabled. Log file: Rithmic.log | 2013-12-15 04:41:05 Rithmic 01 - Connecting to Rithmic 01 US server. | 2013-12-15 04:41:05 Rithmic 01 - Server Alert: Market Data Connection Broken. Error text: | 2013-12-15 04:41:07 Rithmic 01 - Server Alert: Trading System Connection Broken. Error text: | 2013-12-15 04:41:07 Rithmic 01 - Server Alert: PnL Connection Broken. Error text: | 2013-12-15 04:41:07 Rithmic 01 - Server Alert: Intraday History Connection Broken. Error text: | 2013-12-15 04:41:07 Connection timed out. Will disconnect and retry. | 2013-12-15 04:43:04 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2013-12-15 04:43:04 To prevent further connection attempts, select 'File >> Disconnect'. | 2013-12-15 04:43:04 Rithmic 01: Disconnected from the server. | 2013-12-15 04:43:04 Will reconnect to the server in 1.0 seconds Select File >> Disconnect to prevent further connection attempts. | 2013-12-15 04:43:04 Rithmic 01 - Port for executable: 194 | 2013-12-15 04:43:05 Rithmic 01 - Starting server: C:\SierraChart\Rim\GSPBridge.exe | 2013-12-15 04:43:05 Rithmic 01: Connecting to the server 127.0.0.1. Port 194 | 2013-12-15 04:43:06 The network socket is connected. | 2013-12-15 04:43:06 Rithmic 01: Connected to server. | 2013-12-15 04:43:06 Rithmic 01: Sending logon request message. | 2013-12-15 04:43:06 Rithmic 01 - Starting the connection process to data and trading service. | 2013-12-15 04:43:06 Rithmic 01 - Logging is enabled. Log file: Rithmic.log | 2013-12-15 04:43:06 Rithmic 01 - Connecting to Rithmic 01 US server. | 2013-12-15 04:43:06 Rithmic 01 - Server Alert: Market Data Connection Broken. Error text: | 2013-12-15 04:43:08 Rithmic 01 - Server Alert: Trading System Connection Broken. Error text: | 2013-12-15 04:43:08 Rithmic 01 - Server Alert: PnL Connection Broken. Error text: | 2013-12-15 04:43:08 Rithmic 01 - Server Alert: Intraday History Connection Broken. Error text: | 2013-12-15 04:43:08 Connection timed out. Will disconnect and retry. | 2013-12-15 04:45:05 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2013-12-15 04:45:05 To prevent further connection attempts, select 'File >> Disconnect'. | 2013-12-15 04:45:05 Rithmic 01: Disconnected from the server. | 2013-12-15 04:45:05 Will reconnect to the server in 1.0 seconds Select File >> Disconnect to prevent further connection attempts. | 2013-12-15 04:45:05 Rithmic 01 - Port for executable: 27074 | 2013-12-15 04:45:06 Rithmic 01 - Starting server: C:\SierraChart\Rim\GSPBridge.exe | 2013-12-15 04:45:06 Rithmic 01: Connecting to the server 127.0.0.1. Port 27074 | 2013-12-15 04:45:07 The network socket is connected. | 2013-12-15 04:45:07 Rithmic 01: Connected to server. | 2013-12-15 04:45:07 Rithmic 01: Sending logon request message. | 2013-12-15 04:45:07 Rithmic 01 - Starting the connection process to data and trading service. | 2013-12-15 04:45:07 Rithmic 01 - Logging is enabled. Log file: Rithmic.log | 2013-12-15 04:45:07 Rithmic 01 - Connecting to Rithmic 01 US server. | 2013-12-15 04:45:07 Rithmic 01 - Server Alert: Market Data Connection Broken. Error text: | 2013-12-15 04:45:09 Rithmic 01 - Server Alert: Trading System Connection Broken. Error text: | 2013-12-15 04:45:09 Rithmic 01 - Server Alert: PnL Connection Broken. Error text: | 2013-12-15 04:45:09 Rithmic 01 - Server Alert: Intraday History Connection Broken. Error text: | 2013-12-15 04:45:09 Connection timed out. Will disconnect and retry. | 2013-12-15 04:47:17 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2013-12-15 04:47:17 To prevent further connection attempts, select 'File >> Disconnect'. | 2013-12-15 04:47:17 Rithmic 01: Disconnected from the server. | 2013-12-15 04:47:17 Will reconnect to the server in 1.0 seconds Select File >> Disconnect to prevent further connection attempts. | 2013-12-15 04:47:17 Rithmic 01 - Port for executable: 45762 | 2013-12-15 04:47:18 Rithmic 01 - Starting server: C:\SierraChart\Rim\GSPBridge.exe | 2013-12-15 04:47:18 Rithmic 01: Connecting to the server 127.0.0.1. Port 45762 | 2013-12-15 04:47:19 The network socket is connected. | 2013-12-15 04:47:19 Rithmic 01: Connected to server. | 2013-12-15 04:47:19 Rithmic 01: Sending logon request message. | 2013-12-15 04:47:19 Rithmic 01 - Starting the connection process to data and trading service. | 2013-12-15 04:47:19 Rithmic 01 - Logging is enabled. Log file: Rithmic.log | 2013-12-15 04:47:19 Rithmic 01 - Connecting to Rithmic 01 US server. | 2013-12-15 04:47:19 Rithmic 01 - Server Alert: Market Data Connection Broken. Error text: | 2013-12-15 04:47:21 Rithmic 01 - Server Alert: Trading System Connection Broken. Error text: | 2013-12-15 04:47:21 Rithmic 01 - Server Alert: PnL Connection Broken. Error text: | 2013-12-15 04:47:21 Rithmic 01 - Server Alert: Intraday History Connection Broken. Error text: | 2013-12-15 04:47:21 Connection timed out. Will disconnect and retry. | 2013-12-15 04:49:18 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2013-12-15 04:49:18 To prevent further connection attempts, select 'File >> Disconnect'. | 2013-12-15 04:49:18 Rithmic 01: Disconnected from the server. | 2013-12-15 04:49:18 Will reconnect to the server in 1.0 seconds Select File >> Disconnect to prevent further connection attempts. | 2013-12-15 04:49:18 Rithmic 01 - Port for executable: 7107 | 2013-12-15 04:49:19 Rithmic 01 - Starting server: C:\SierraChart\Rim\GSPBridge.exe | 2013-12-15 04:49:19 Rithmic 01: Connecting to the server 127.0.0.1. Port 7107 | 2013-12-15 04:49:20 The network socket is connected. | 2013-12-15 04:49:20 Rithmic 01: Connected to server. | 2013-12-15 04:49:20 Rithmic 01: Sending logon request message. | 2013-12-15 04:49:20 Rithmic 01 - Starting the connection process to data and trading service. | 2013-12-15 04:49:20 Rithmic 01 - Logging is enabled. Log file: Rithmic.log | 2013-12-15 04:49:20 Rithmic 01 - Connecting to Rithmic 01 US server. | 2013-12-15 04:49:20 Rithmic 01 - Server Alert: Market Data Connection Broken. Error text: | 2013-12-15 04:49:22 Rithmic 01 - Server Alert: Trading System Connection Broken. Error text: | 2013-12-15 04:49:22 Rithmic 01 - Server Alert: PnL Connection Broken. Error text: | 2013-12-15 04:49:22 Rithmic 01 - Server Alert: Intraday History Connection Broken. Error text: | 2013-12-15 04:49:22 Connection timed out. Will disconnect and retry. | 2013-12-15 04:51:19 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2013-12-15 04:51:19 To prevent further connection attempts, select 'File >> Disconnect'. | 2013-12-15 04:51:19 Rithmic 01: Disconnected from the server. | 2013-12-15 04:51:19 Will reconnect to the server in 1.0 seconds Select File >> Disconnect to prevent further connection attempts. | 2013-12-15 04:51:19 Rithmic 01 - Port for executable: 27843 | 2013-12-15 04:51:20 Rithmic 01 - Starting server: C:\SierraChart\Rim\GSPBridge.exe | 2013-12-15 04:51:20 Rithmic 01: Connecting to the server 127.0.0.1. Port 27843 | 2013-12-15 04:51:21 The network socket is connected. | 2013-12-15 04:51:21 Rithmic 01: Connected to server. | 2013-12-15 04:51:21 Rithmic 01: Sending logon request message. | 2013-12-15 04:51:21 Rithmic 01 - Starting the connection process to data and trading service. | 2013-12-15 04:51:21 Rithmic 01 - Logging is enabled. Log file: Rithmic.log | 2013-12-15 04:51:21 Rithmic 01 - Connecting to Rithmic 01 US server. | 2013-12-15 04:51:21 Rithmic 01 - Server Alert: Market Data Connection Broken. Error text: | 2013-12-15 04:51:23 Rithmic 01 - Server Alert: Trading System Connection Broken. Error text: | 2013-12-15 04:51:23 Rithmic 01 - Server Alert: PnL Connection Broken. Error text: | 2013-12-15 04:51:23 Rithmic 01 - Server Alert: Intraday History Connection Broken. Error text: | 2013-12-15 04:51:23 Connection timed out. Will disconnect and retry. | 2013-12-15 04:53:20 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2013-12-15 04:53:20 To prevent further connection attempts, select 'File >> Disconnect'. | 2013-12-15 04:53:20 Rithmic 01: Disconnected from the server. | 2013-12-15 04:53:20 Will reconnect to the server in 1.0 seconds Select File >> Disconnect to prevent further connection attempts. | 2013-12-15 04:53:20 Rithmic 01 - Port for executable: 48579 | 2013-12-15 04:53:21 Rithmic 01 - Starting server: C:\SierraChart\Rim\GSPBridge.exe | 2013-12-15 04:53:22 Rithmic 01: Connecting to the server 127.0.0.1. Port 48579 | 2013-12-15 04:53:23 The network socket is connected. | 2013-12-15 04:53:23 Rithmic 01: Connected to server. | 2013-12-15 04:53:23 Rithmic 01: Sending logon request message. | 2013-12-15 04:53:23 Rithmic 01 - Starting the connection process to data and trading service. | 2013-12-15 04:53:23 Rithmic 01 - Logging is enabled. Log file: Rithmic.log | 2013-12-15 04:53:23 Rithmic 01 - Connecting to Rithmic 01 US server. | 2013-12-15 04:53:23 Rithmic 01 - Server Alert: Market Data Connection Broken. Error text: | 2013-12-15 04:53:24 Rithmic 01 - Server Alert: Trading System Connection Broken. Error text: | 2013-12-15 04:53:24 Rithmic 01 - Server Alert: PnL Connection Broken. Error text: | 2013-12-15 04:53:24 Rithmic 01 - Server Alert: Intraday History Connection Broken. Error text: | 2013-12-15 04:53:24 Connection timed out. Will disconnect and retry. | 2013-12-15 04:55:22 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2013-12-15 04:55:22 To prevent further connection attempts, select 'File >> Disconnect'. | 2013-12-15 04:55:22 Rithmic 01: Disconnected from the server. | 2013-12-15 04:55:22 Will reconnect to the server in 1.0 seconds Select File >> Disconnect to prevent further connection attempts. | 2013-12-15 04:55:22 Rithmic 01 - Port for executable: 9156 | 2013-12-15 04:55:23 Rithmic 01 - Starting server: C:\SierraChart\Rim\GSPBridge.exe | 2013-12-15 04:55:23 Rithmic 01: Connecting to the server 127.0.0.1. Port 9156 | 2013-12-15 04:55:24 The network socket is connected. | 2013-12-15 04:55:24 Rithmic 01: Connected to server. | 2013-12-15 04:55:24 Rithmic 01: Sending logon request message. | 2013-12-15 04:55:24 Rithmic 01 - Starting the connection process to data and trading service. | 2013-12-15 04:55:24 Rithmic 01 - Logging is enabled. Log file: Rithmic.log | 2013-12-15 04:55:24 Rithmic 01 - Connecting to Rithmic 01 US server. | 2013-12-15 04:55:24 Rithmic 01 - Server Alert: Market Data Connection Broken. Error text: | 2013-12-15 04:55:25 Rithmic 01 - Server Alert: Trading System Connection Broken. Error text: | 2013-12-15 04:55:25 Rithmic 01 - Server Alert: PnL Connection Broken. Error text: | 2013-12-15 04:55:25 Rithmic 01 - Server Alert: Intraday History Connection Broken. Error text: | 2013-12-15 04:55:26 Connection timed out. Will disconnect and retry. | 2013-12-15 04:57:23 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2013-12-15 04:57:23 To prevent further connection attempts, select 'File >> Disconnect'. | 2013-12-15 04:57:23 Rithmic 01: Disconnected from the server. | 2013-12-15 04:57:23 Will reconnect to the server in 1.0 seconds Select File >> Disconnect to prevent further connection attempts. | 2013-12-15 04:57:23 Rithmic 01 - Port for executable: 29892 | 2013-12-15 04:57:24 Rithmic 01 - Starting server: C:\SierraChart\Rim\GSPBridge.exe | 2013-12-15 04:57:24 Rithmic 01: Connecting to the server 127.0.0.1. Port 29892 | 2013-12-15 04:57:25 The network socket is connected. | 2013-12-15 04:57:25 Rithmic 01: Connected to server. | 2013-12-15 04:57:25 Rithmic 01: Sending logon request message. | 2013-12-15 04:57:25 Rithmic 01 - Starting the connection process to data and trading service. | 2013-12-15 04:57:25 Rithmic 01 - Logging is enabled. Log file: Rithmic.log | 2013-12-15 04:57:25 Rithmic 01 - Connecting to Rithmic 01 US server. | 2013-12-15 04:57:25 Rithmic 01 - Server Alert: Market Data Connection Broken. Error text: | 2013-12-15 04:57:26 Rithmic 01 - Server Alert: Trading System Connection Broken. Error text: | 2013-12-15 04:57:27 Rithmic 01 - Server Alert: PnL Connection Broken. Error text: | 2013-12-15 04:57:27 Rithmic 01 - Server Alert: Intraday History Connection Broken. Error text: | 2013-12-15 04:57:27 Connection timed out. Will disconnect and retry. | 2013-12-15 04:59:24 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2013-12-15 04:59:24 To prevent further connection attempts, select 'File >> Disconnect'. | 2013-12-15 04:59:24 Rithmic 01: Disconnected from the server. | 2013-12-15 04:59:24 Will reconnect to the server in 1.0 seconds Select File >> Disconnect to prevent further connection attempts. | 2013-12-15 04:59:24 Rithmic 01 - Port for executable: 56004 | 2013-12-15 04:59:25 Rithmic 01 - Starting server: C:\SierraChart\Rim\GSPBridge.exe | 2013-12-15 04:59:25 Rithmic 01: Connecting to the server 127.0.0.1. Port 56004 | 2013-12-15 04:59:26 The network socket is connected. | 2013-12-15 04:59:26 Rithmic 01: Connected to server. | 2013-12-15 04:59:26 Rithmic 01: Sending logon request message. | 2013-12-15 04:59:26 Rithmic 01 - Starting the connection process to data and trading service. | 2013-12-15 04:59:26 Rithmic 01 - Logging is enabled. Log file: Rithmic.log | 2013-12-15 04:59:26 Rithmic 01 - Connecting to Rithmic 01 US server. | 2013-12-15 04:59:26 Rithmic 01 - Server Alert: Market Data Connection Broken. Error text: | 2013-12-15 04:59:28 Rithmic 01 - Server Alert: Trading System Connection Broken. Error text: | 2013-12-15 04:59:28 Rithmic 01 - Server Alert: PnL Connection Broken. Error text: | 2013-12-15 04:59:28 Rithmic 01 - Server Alert: Intraday History Connection Broken. Error text: | 2013-12-15 04:59:28 Connection timed out. Will disconnect and retry. | 2013-12-15 05:01:25 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2013-12-15 05:01:25 To prevent further connection attempts, select 'File >> Disconnect'. | 2013-12-15 05:01:25 Rithmic 01: Disconnected from the server. | 2013-12-15 05:01:25 Will reconnect to the server in 1.0 seconds Select File >> Disconnect to prevent further connection attempts. | 2013-12-15 05:01:25 Rithmic 01 - Port for executable: 17349 | 2013-12-15 05:01:26 Rithmic 01 - Starting server: C:\SierraChart\Rim\GSPBridge.exe | 2013-12-15 05:01:26 Rithmic 01: Connecting to the server 127.0.0.1. Port 17349 | 2013-12-15 05:01:27 The network socket is connected. | 2013-12-15 05:01:27 Rithmic 01: Connected to server. | 2013-12-15 05:01:27 Rithmic 01: Sending logon request message. | 2013-12-15 05:01:27 Rithmic 01 - Starting the connection process to data and trading service. | 2013-12-15 05:01:27 Rithmic 01 - Logging is enabled. Log file: Rithmic.log | 2013-12-15 05:01:27 Rithmic 01 - Connecting to Rithmic 01 US server. | 2013-12-15 05:01:27 Rithmic 01 - Server Alert: Market Data Connection Broken. Error text: | 2013-12-15 05:01:29 Rithmic 01 - Server Alert: Trading System Connection Broken. Error text: | 2013-12-15 05:01:29 Rithmic 01 - Server Alert: PnL Connection Broken. Error text: | 2013-12-15 05:01:29 Rithmic 01 - Server Alert: Intraday History Connection Broken. Error text: | 2013-12-15 05:01:29 |
[2013-12-15 10:05:06] |
100 - Posts: 147 |
I disconnected my rj45 from the back of my computer for a day or two. I believe it may have reset my IP, etc. Idk if that is the issue. I'll try contacting Rithmic on Monday. Thank you. |
