Date/Time: Sun, 12 May 2024 17:24:56 +0000
YPOC
View Count: 698
[2019-10-01 23:49:59] |
DGee - Posts: 82 |
How do I make a distinction between today's volume point of control (VPOC) and yesterday's POC (YPOC)? I see in the volume profile study that you can extend the lines but you have to use the same colors and nowhere to auto label it differently. My label I believe is standard and only labels POC but not yesterday's if you set to "extend to both windows". I want YPOC to come across today's session to identify it. Can you help me distinguish between the two on the screen? Attached file to show what I mean. Thank you!
POC_Sierra.PNG / V - Attached On 2019-10-01 23:48:59 UTC - Size: 64.5 KB - 264 views |
[2019-10-02 12:25:55] |
You cannot accomplish this if you extend that line to the End of Window.
