Date/Time: Sat, 04 May 2024 02:50:31 +0000
OPEN_CHARTBOOK
View Count: 1259
[2013-12-13 14:32:39] |
jesslinn - Posts: 108 |
Is there a way to direct a UDP 22903 message to a specific instance of SC? It seems that one can only send messages to the first one that is started. Is it possible to configure a given instance to listen on another port for example? |
[2013-12-13 18:04:06] |
We will have to add a setting to specify the port number.
