Date/Time: Sun, 05 May 2024 21:50:25 +0000
color background of evening session with TPO Profile Chart study and VbP study
View Count: 1443
[2013-12-13 13:43:35] |
User16114 - Posts: 153 |
when using the "TPO Profile Chart" study and trying to color background using "Time Range Highlight" or "Time Range Highlight - Transparent" the colored background covers the TPOs (TPOs are not visible) but does not cover the Volume by Price study (volume by price study is visible). I have tried to "Time Range..." to color the evening session background with "Draw Study Underneath Main Price Graph" both checked and not checked. Can you suggest a way to color the evening session background when using the "TPO Profile Chart" study and have both TPOs and VbP study visible. Thanks! |
[2013-12-13 19:19:37] |
This will be resolved in the next release.
[2013-12-14 03:11:41] |
downloaded 1062 pre-release and issue fixed - thanks!
