Date/Time: Wed, 01 May 2024 14:01:20 +0000
Volume by Price Request to Length of bars relative to X volume
View Count: 613
[2019-09-27 03:04:18] |
AlexPereira - Posts: 197 |
Hi, Thanks for the great platform ! I have a chart which has VbP study in each candle. Would it be possible to set the length of the volume profile bars relative to a specified volume number? I tried the setting "Volume Profile Bars Length Relative to All Visible Profiles", but what I am looking for is to specify it with a number like an average volume of all candles in the chart ( number that i would get from another study and then set on the VbP study manually). Could a setting that would do the effect of "Volume Profile Bars Length Relative to All Visible Profiles", but instead to a XXX manual number be done ? Thanks ! |
[2019-10-07 16:25:56] |
sorry, i know you guys have lots of work to do, was this a not seen message, or just a "WONT DO" kinda of thing ?
[2019-10-08 02:06:32] |
We cannot take any new requests now.
